Subdomain and htdocs
Hi there
I am not too familar with the subdomain but I was asked to create a page for my friend. the web site is hosted by PlusNet - www.company.com and now I likes to create a page - client.company.com so I can create a link pointing to it. After reading many great threads in this forum, I have drafted a procedure like this:
1. create a DNS A record
www A 80.111.111.111
2. create a DNS CNAME record
client CNAME company.com
3. create a "client" subfolder in the htdocs folder
4. upload web pages to the subfolder
Is this procedure correct? and if I change the domain hosting setting from default to other in the Configure Domain page, will it affect the email system? I would be grateful if anyone can help me with this problem, thanks
That is incorrect.
Use the following procedure.
1: Create a DNS record as follows
Left field: client
Type: CNAME
Pri: leave blank
Right field: homepages.plus.net
2: Raise a link:contact us using the domain import path, to import the domain "client.domain.co.uk" (where domain is your own).
3: Once imported by PlusNet, you can set this new domain to point to the required folder under htdocs
Thanks for your kind instruction. I will create the subdomain first and then raise a contact us.
