Sub Domain's
Sub Domain's
Hello Smiley,
I am a newbie to domains ect but i have just got one! i would like to know how i can do sub domains if anyone could tell me please?
1 REPLY
Sub Domain's
To create a sub-domain, goto http://portal.plus.net and select domain names, select configure next to your domain name, click configure dns, click add.
now lets say you wanted jo.bloggs.co.uk (assuming bloggs is the domain name you chose) then you would put
left=jo
type=a
pri=(blank)
right=(your static IP address)
you might want to creat one for www so that it knows to serve this also.
If you do not have a static IP, then you can get one from the "my control panel" section of the portal. Note:- Subscription accounts only...
Dave
