Streaming Audio Using Shoutcast
My son wants to setup his own "Radio Station" using Shoutcast Server. We have a static IP from Plusnet and the necessary server software from Nullsoft.
The listeners attach using the IP address and a port number assigned by the server software. Can we do this on plusnet? is this type of connection supported? Has anyone else done this before
1 REPLY
Yes you can do this if running on your home PC - but bear in mind uploads are counted as well as downloads from your connection, so this will affect your usage stats a fair bit. If you're running a firewall, dont forget to open the service port specified by the software.
