Steganos Internet Anonym 6.0.8
Hi all,
Any help appreciated. I've installed the above program today, but I'm now getting a lot of DNS pages, I mean anything and everything. I'm using XP home and just having major problems.
Does anyone use this program and if so have you had the same problems and what were the fixes?
I don't want anyone to see my IP as I'm surfing the net, I hadn't until recently realised how much all the sites could see.
Regards
witty
I tied it once and put it in the bin. If you dont want to be seen then you just use a proxy server as all that is seen then is the proxy IP.
If you search google for free proxies you should find loads. All these software products basicly do the same they connect you via a proxy.
Thank you Mwright. Grately appreciated. Cheesy
Witty
