Static IP, can it be changed?
Hey,
Is it possible to change you static ip address?
Thanks in Advanced,
Tim
All PlusNet ADSL products come with a static IP address as standard. In fact, it's not possible for you to get a dynamic IP address on PlusNet's ADSL products.
So your IP is already static Smiley
No, i no that, im using a static ip already, but is it possible to get a different static ip?
Thanks in Advanced,
Tim
yeah you can get a new one if for a good reason, but no idea what a good reason is for that request.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Ah apologies - I thought you said change to a static IP Smiley
If you raise a link:contact us ticket and go through the following path:
  • Technical Support (Except Connection Problems - See below)
    • Static IP / Reverse DNS Setup
      • Change my Static IP Address
Enter any relevant information into the box (such as a reason for changing IP address) and press Submit. Apologies for incorrectly reading the initial query Smiley
