Spyware removal
Spyware removal
I am trying to find some free spyware removal software to get rid of the Perfect Nav hijacking Internet Explorer all the time. Can anybody reccommend any?
Moderators note (John) Title altered from all capitals to lower case. Please do not use all capitals as it's akin to shouting.
Spyware removal
Try the following tutorial: General: Essential Security software. Spybot search & destroy and Adaware are the leading utils to try (and use both as they each find things the other does not)
Spyware removal
Serch for and install SpywareBlaster. It prevents a lot of things getting installed in the first place
Spyware removal
check out
www.janwright.co.uk/new.htm
there is links to many spyware removers, hyjack is a bad one and cwwshredder and hijack are the only tool to get rid of it.
I cant understand why these people are not prosicuted as a lot of these things are worse than the virus
