Speedtouch 716wl v5 - new v6.1 firmware
This new firmware has appeared on the Speedtouch website. I installed it OK this morning but don't know what the changes are yet.
The upgrade wizard only seemed to work after I'd disabled windows firewall. I can't see any difference either. I was hoping it would allow me to add multiple SIP Registrar so that I could use plustalk for outgoing calls and sipgate for incoming regional code number.
Any way, I'll keep an eye on this page...
http://www.voip-info.org/wiki/index.php?page=Speedtouch%20716%20/%20716%20v5%20WL
...for information about the new firmware.
One change I have found is that when you have VoIP enabled you can dial 9 for a PSTN line to make a call Cheesy
That's been there since the last firmware release.
R6.1 Release Notes
I got some release notes from Speedtouch on what's in 6.1 - its nothing very exciting.
Here are the edited highlights - I can't seem to post the whole PDF.
Following VoIP features have been added:
􀀗 Voice SIP update for keep alive
􀀗 3-party for US
􀀗 American analog phone settings
􀀗 DHCP TR-069 WT121 (look alike, not exactly implemented according to
WT121)
􀀗 SDP body owner creator field (partly)
􀀗 Ending dial input with * instead of #
􀀗 Configuration scenario for UPC, TDC, Fastweb
􀀗 CLIP/CLIR (**** support)
􀀗 OPTIONS message support
􀀗 Timer setting for SIP compliance (1000 to 500 ms)
􀀗 SIP ALG host traffic tagging
􀀗 Call forwarding on Busy
􀀗 Call forwarding Unconditional
􀀗 SIP-ALG to correctly handle PRACK
􀀗 Multiple common numbers
A dedicated software release R6.1.7 has been introduced adding following
fixes and features:
􀀗 SIP Dialtone & ringing can get lost in multiple different scenarios (which
will not occur very often).
􀀗 SIP support for symmetric calls
􀀗 T38 REINVITE from caller, reinvite at calling fax detection (Not
according to standard)
􀀗 SIP replace#
􀀗 MGCP static interface binding
Following various fixes and improvements have been introduced in software release
R6.1:
􀀗 TR-069 fixes ( save / interop / scripting )
􀀗 DHCP client link-sensing
􀀗 DHCP client fixes
􀀗 CLI command :ip addroute fix
􀀗 Extend TFTP/DHCP config file download to all SpeedTouch™ platforms
􀀗 Flexiport extension ("move" iso "add" command)
􀀗 Voice over Wi-Fi fix WMM
􀀗 DHCP GUI fixes
􀀗 SYSLOG enabled on SpeedTouch™608 WL
􀀗 SNMPv3 crash fixes (SpeedTouch™620 only)
􀀗 SSL crash fixes (SpeedTouch™620 only)
􀀗 Debug tracing BGP crash fixes (SpeedTouch™620 only)
I still can't get the firmware to take on my 716wl5. The upgrade wizard gets the firmware onto the router and then gives an error. Querying the router then reports it's requested kernel mode due to upload of invalid firmware. Anyone seen this?
Mike
No. My upgrade went without a hitch. However, the date now shows one month out on the configuration page - August instead of September. Although the log shows September.
Chris
