Speedtouch 716WL -anyone got it working ?
Got a ST 716WL with 2 Voip ports - service logs in fine, get a dialtone and can do echotest from handset but when i try to call from another phone to the 0845 number assigned- it goes straight to voicemail.
I got the same hardware and same problem!
Pendragon
I'm probably way off the mark and I expect you have already read this but there is an installation guide for your router here
http://www.plus.net/support/adsl/speedtouch716_setup_guide.shtml?pn_session=59b12237e63ef0f62e236fb6...
Part way down the page I did notice the VoIP settings.
There is a port 5060 used and if your using Windows XP the firewall has a nasty habit of blocking incoming ports.
You may have to open the port to allow the connection.
Just a thought.
There's no XP to it. The router plugs right into the ADSL port, and has phone ports on the back. You don't even need a PC (only to configure it)!
It all works well, apart from incoming calls going straight to voicemail Sad
Well my ticket has been open with technical support for 2 weeks now, 1 week ago they confirmed the problem by configuring their own st716wl on my number - since then the ticket just bounces around the company with no resolution.
