Solwise SAR110 locks up
When I start x-lite, my solwise sar110 adsl modem locks up and needs a reboot (all front lights go on permanently)
So I cannot get it to work at all...
...time for a new router modem perhaps?
Will bash away at it for a while and see if I can make it work
Update - fixed it
telnet into the router, issue the following command:
"delete alg port portno 5060 prot any"
as per this post:
http://www.solwiseforum.co.uk/showthread.php?t=7060
Now logged in without the router locking but have not checked if the rest works yet.
When I had a 110, even that command didn't necessarily fix it permanently. It worked maybe 90% of the time - but that other 10% was very annoying.
