Solwise 130 router + firewall
Just got connected and I have this router.
Is there a best practices guide for BB with a router and/or some firewall rule sets which are considered to be de facto?
Also, how secure is this router firewall? Should it be used in conjunction with a software firewall on the PC? Anyone have an horror stories/must not dos?
Cheers,
Norris
Alecto
Follow the instructions here http://www.sarguide.co.uk/
to stealth the router.
And yes you need a software firewall as well since the router only protects against unsolicited stuff coming in, not against bad programs sending stuff out.
Thanks for your reply.
I run Kerio anyway but wondered if I could cut down on the amount that Kerio does has to do (to avoid duplication). Presumably, I can drop all the 'inbound' firewall rules and just use the application monitor (the dialog which determines which applications are allowed to do what wrt the net) ?
Cheers,
Norris
Alecto
Hi Norris
I can't see what you'd gain there.
My software firewall is set up just as it was when I was on dialup before I had the router.
I suppose it's a "belt and braces" mentality, but I'd rather have software checking that the hardware is doing its job (where possible.)
Geoff
I would leave kerio to monitor both inbound and outbound connections. That way, if you mess up the hardware firewall config you will still be protected.
I should explain that the driver for my question was online gaming with my ageing rig and trying to reduce the amount of background tasks/RAM used; i.e. binning Kerio and playing via an empty "gaming" user account under XP.
You're right, though, with the belt and braces - I was just thinking that it seems a bit daft to have a software firewall going through the motions when there is a 'more secure' firewall there in the first place...
I was then going to set the router up in stealth mode as suggested in the link provided by Geoff then perform a few firewall tests to ensure that it's actually blocking OK. However, I know that nothing is perfect and if the router was totally secure, the NSA would be using them by the bucketload Wink so I'll try keep both.
Cheers,
Norris
