Softphone recomentation
Nick_Russell
:?: Can anyone suggest a VoIP softphone to use with a SIP service? I have tried X-Lite and X-Pro. The actual softphone looks good but the operation is not very user friendly. It is a bit clumsy adding new address book entries and dialling from address book, or adding new services.
Ideally I am looking for a SIP softphone that is as easy to use and as good looking as Skype.
Any ideas?
SJphone is an alternative software, the quality with microphone and headphones is a little better. http://www.sjlabs.com/ I use that.
If you download and use it, right click the 'face' and select options >>>>>>>>> profiles, then create a new profile.
I purchased a Waitec E-ZI VOIP USB phone, a download of the SJPhone-mate software and the quality is as good as a Land Line phone. The phone was just under £23-00. Being impatient i ordered it and paid the p&p, total under £30-00.
Nick_Russell
Express Talk softphone.
Found this....its great. Very easy to set up and MUCH easier to use than X-Lite
http://www.nch.com.au/talk/
I would suggest Plus Talk users try this - the softphone looks very similar to Skype and very easy to add address book entries.
During set-up when prompted select the option something like "I already have a SIP account" and add Plus Talk details.
Can you use a usb phone with that ?
Nick_Russell
Forgive me if I misunderstand, but Express Talk and X-Lite are software phones (so-called softphones as there is no hardware necessary to use except microphone/loudspeaker or headset attached to your PC/laptop).
If by USB phone you mean headset, yes this is fine - it works just like X-Lite but it’s just easier to use and looks much better.
I am not an expert on such matters but if you are talking about a dedicated VoIP hardware telephone I understood this plugs into a router and not a USB port, and I’m not sure either X-Lite or Express talk would be necessary.
You can purchase VOIP hardware phones that plug into a USB, most (if not all) require sofware to connect them. see this thread
Nick_Russell
I don't know but Express Talk is free - why not try it?
What is the advantage of a USB hardware telephone that plugs into a PC compared with a headset or built in microphone/speakers in a laptop? Other hardware VoIP telephones will work with PC turned off if they connect to a router, but a USB telephone will presumably need PC on so why not use headset or build in devices?
They give better audio quality.
