Skype dropping connection...
Hi y'all,
Just installed Skype on an XP box.
Internet connection is thru a W2K machine with a 56k modem attached.
Every time a Skype connection is made from XP, the modem is disconnected after 60 seconds.
Does PlusNet allow Skype connections, if so any ideas what might be causing the modem to disconnect ?
FWIW, I can leave the internet open with no traffic for an hour before the modem disconnects, so it isn't a time out issue.
TIA
Dave
Check your modem has the latest drivers installed.
This douns like either a driver issue, causing the modem to disconnect for some reason or another.
PlusNet allow skype with no issues here.
Thanks for the info, much appreciated.
