Sipura spa 3000
Sipura spa 3000
anyone know how to get plustalk working with this ?
i have sipgate on line 1 so i have a local dial in number Cheesy , i have voipuser on pstn line, then i have voip talk and FWD on gateways 1 and 2. would like to have plustalk on gateway 3 if possible?
shamus
Sipura spa 3000
I literally spent days getting this to work...
Gateway 3: sip.plus.net
GW3 Auth ID: plustalk
GW3 Password: your plusnet password
Not sure what you should set the "GW3 NAT Mapping Enable:" to as I dont use NAT - Probably worth setting to the same as you have for GW1 & 2.
HTH
Shaun
Sipura spa 3000
HTH
Shaun
Something must have changed since you did it as the only way i can get it to allow me to use it for outgoing calls is:
GW3 Auth ID: my plustalk number
GW3 Password: my plusnet password
GW3 NAT Mapping Enable to yes
can now get to my voice mail that i forward from another account Cheesy
thanks for pointing me in the right direction Smiley
Jon
