Siemens c460 IP SIP phone
Hello
I have just got a Siemens c460 IP phone that is fully SIP compatible, should this in theory work with plus net to make my broadband phone calls?
Peter
I wish I could say it would - but I have not managed to get mine to work so far.... Cry
I am going to give it another try later in the week... will let you know progress.
Siemens support
Well I hope you have more luck than me. I am returning mine and may try another one in case my set was faulty.
I called Siemens help desk in some country and was a little pissed that the only thing they would do is make me do the connection assistant on the phone which I had already done and it seemed to work, but wouldn't answer any other questions which is Siemens fault for not offering 2nd line support.
Oh well. Wish I new of some other phones wireless that do the same thing, would try those..
try
http://www.provu.co.uk/voip_products.html
they do a lot of phones. Not necessarily the cheapest place but at least its a starting point.
I am trying another siemens c460 ip phone because I found out you need at least a 3 metre seperation between wireless products or you get conflicts in the wifi band.
Nobody told me this when setting up the first time, so I hope this will work. ~Getting it from broadband buyer, they always have taken time to explain new products even when I don't order.
Peter
Well
I cna't believe it but this guy at the main Siemens distributor took a day to sort out what was wrong
1)Things didn't work with sip.plus.net it needed ip addresses and he said most of the servers seeemed flakey, this address ok - 84.92.5.189
The SIP server addresses are as follows:
84.92.0.75
84.92.0.76
84.92.5.189
84.92.5.190
and use the STUN server address for XLITE. My phone works now and is stable.
could you post the full settings?
A screen shot would be nice - blank out password of course Cheesy
Ive completly filed to get it to work with plusnet
ha, success - after 3 months with C460IP i now have VOIP through plus.net
I wounder why sip.plus.net doesnt work
Cheers for help - if anyone else is intreasted I will post the setting details.
- NB: not sure if incoming calls are recived and I am not going to test it Smiley
Settings for Gigaset C460/ C450 IP:
* indicates a default setting
Authentication Name: Plusnet SIP id e.g. 123456
Authentication Password: Plusnet account password
Username: Plusnet SIP id e.g. 123456
Domain: plusnet_username.plus.com
Display Name: plusnet_username
Proxy Server Address: 84.92.5.189
Proxy Server Port: 5060 *
Registrar Server Address: 84.92.5.189
Registrar Server Port: 5060 *
STUN Enabled: YES
STUN Server: stun.sipgate.net
NAT Refresh time: 20 sec *
Outbound Proxy Mode: Always
Outbound Proxy: 84.92.5.189
Outbound Proxy Port: 5060 *
The rest are default settings
robpete - if your set up is different let me know.
siemens
good news on getting yours sorted.
I found out that in fact the wireless is on a different frequency than the Siemens 2.4ghz and 1.9 so there is no conflict, broadbandbuyer got it wrong.
The settings that worked perfectly for a week. My laptop or something is screwy (installed and used Tuneup Utility?) cause now something has gone wonky conerning the siemens phome as its the dreaded message - sip registration failed.
Only difference is the sip server 84.92.5.158 is also used for the domain and the stun server
was stun.xten.net
Pete
