Should I just go DSL
My connection speed between 6.00pm an 10.00pm has been getting worse and worse over the past couple of months. It has got to the point where I can't play online games due to the lag. I have informed force9 but I have been told that BT will only accept there is a speed fault when I get slow speed test results during off-peak times.
I am guessing that the line will be the same with any adsl provider so should I go DSl. Thanks in advance for any advice.
astarsolutions
If you live in an area served by a cable provider then from what I understand a cable Internet connection is far better and always the preferred choice.
ok thanks
