Setting up personal server?
I run my internet of a Netgear DG834G I can't seem to set up a personal server using blackmoon FTP server. It will not recognise my static IP only my internal IP. I assume there is some port setting need doing from the server control panel any suggestions?
You can not route from your own (internal) network, to your external Plus.Net IP address.
Chilly
So there is NO way you can run a personal FTP/Sever from my PC because I use a router?
LiamM
For FTP, you simply need to route port 21 through to the LAN IP with the FTP Server installed.
It should then be visible to the outside world.
