Setting up my own forum on my webspace
technogogo
I want to create a forum in my webspace so a few of my friends can leave messages for each other.
I see there are a few open-source forum packages based on php and my-sql. But whats the best package to use from Plusnet's webspace servers?
Skills-wise I am familiar with HTML and have played around with simple PHP scripts. I just could use some recommendations about the best package to get started.
cheers, Mark
You can't run a forum in your www webspace, it must be installed on the cgi server.
Why not use phpBB, (PlusNet use it for this forum) and we have a tutorial which explains how to install it: Scripts: Help Installing phpBB. You don't need any php or HTML skills to install and run it.
technogogo
Ah excellent, thanks Peter. Thats exactly what I needed to get going.
I'd looked for forum start-up info here on the PlusNet portal/forums... guess I didn't look hard enough.
In other news.... You know how sometimes you find something that feels like its giving you a glimpse into the future? Well I stumbled onto something like that this week --- http://www.cluetrain.com/
Kind of like open-source for marketing types. Worth a read.
Thx, Mark
