Setting up VOIP Help
OshB5
Im using a Thomson Speedtouch 780wl
Here are my settings as I have got them from F9,s site
Telephony Identity
SIP URI: 217123
Username: plustalk
Password: *******
Confirm Password: *******
Displayname: AndyS
Abbreviated number: (I left this blank)
Then
Service Configuration
Registrar: sip.force9.net
Registrar Port: 5060
Proxy: sip.force9.net
Proxy Port: 5060
Expire Time: 3600
And this it What i keep getting back. In the logs are
00:26:02 (since last boot) VOIP: Recv 100 Trying
00:26:02 (since last boot) VOIP: Send REGISTER
00:26:02 (since last boot) VOIP: Recv 407 Proxy Authentication Required
00:26:00 (since last boot) VOIP: Recv 100 Trying
00:26:00 (since last boot) VOIP: Send REGISTER
00:26:00 (since last boot) VOIP: Recv 407 Proxy Authentication Required
00:25:59 (since last boot) VOIP: Recv 100 Trying
00:25:59 (since last boot) VOIP: Send REGISTER
00:25:59 (since last boot) VOIP: Recv 407 Proxy Authentication Required
00:25:57 (since last boot) VOIP: Recv 100 Trying
00:25:57 (since last boot) VOIP: Send REGISTER
Anyone see where im going wrong.
Just one thing as yet i have fitted any phones to the voip port of the thomson speed touch 780wl does this matter
Many thanks and best regards Andy
Pendragon
You may not be doing anything wrong.
I have just tried my X-Lite phone today and am getting the same error message. It always has worked fine but I've not used it for about a month.
Raise it as a 'ticket' and see if F9 know of a problem.
Regards, Colin.
Pendragon
Ah Ha, silly me, I forgot I changed the master password on my account due to the recent security problems Shockedops:.
Updated the password and all is now well. I would double check your username and password details are correct.
Regards, Colin.
OshB5
Hello yes i found out it is the username I should have put the sip number in Duh.. :shock: .. Do you know if you can have Cid or your number sending when you call out
Regs Andy
Pendragon
I don’t really know the answer as I don’t have an incoming 0845 number activated on my line (don’t get enough calls to make it worthwhile), it would be down to the ‘far end’ settings at F9’s servers.
Easy way to test is ring your home or a friends landline number (if you have caller display) and see what comes up.
Regards, Colin.
Plusnet Staff
Plusnet Staff
At the moment you can't unfortunately, it will be withheld on PSTN calls. Something to look into at a later date I expect.
speedtouch 716ml ver 5
Everybody who has a speedTouch 716wl ver5 don't update to the latest firmware, it has a big bug in it.
It will make the phone port 1 light up all the time and you will not get a dial tone to make calls.
This is the phone port 1 and not the VoIP ready light which also turned on normally
Michael
