Seting up FTP, HTTP, Mail servers
hey im going to set up a ftp and htttp server, its main use is to be a web hosting companie sort of thing, also i want it to have a good interface to cofig it and i want the ftp and http programs to be seperate ie not an all in one package which are the best programs Huh?? also if i did a mail server which is the best programHuh
csogilvie
Which operating system?
Windows Xp Pro
painswck
Hi assimulator,
Having read several of your posts across a lot of the forums I would suggest you do a lot more research before hosting other peoples files.
Surprising what information and tutorials you can find by careful searching using google.
michaelscott
Indeed. Using an ADSL connection to host lots of files could end up being quite slow - especially as even 2Mb lines are limited to 256k upstream.
2 things
As michaelscott says, 256k upload isn't going to get you anywhere if your trying to run a reasonable business venture.
Secondly, you should at least be on a business account.
i am on a business acount
but anyway what is the best web hosting programHuh
michaelscott
CPanel's WebHost Manager is the best IMO: http://www.cpanel.net/ but it currently will only run on Red Hat, Mandrake, FreeBSD, OS X, SuSE and Red Hat Fedora systems.
Again, it's going to be very slow running off 256k.
ok, is there any really good ones that are free?Huh
michaelscott
i doubt it. you'd have to configure things manually instead.
I've used Webmin before, and found it to be a reasonable free alternative. On the downside it's not all that user friendly, and requires a bit of getting used to. Also I don't think there are Windows versions of it.
csogilvie
Erm, Wemin doesn't work on Windows according to the site...
Wink
csogilvie
Well, it does beg the question why did you post it since he was looking for windows things Tongue
(I didn't notice that til I changed computers)
