Sending SMS
Sending SMS
I want to create a website where users can send free sms to UK Networks, is thier anyhow i can do this by building any type of servers, or if thiers anywebsites that has reslling rights or somthing liek that, pls help if posible
thanks
Sending SMS
I recomend Clickatell/ I use this for the usertools SMS service status updates.
Sending SMS messages is not all that cheap.It is actualy quite expensive for the size of the data transmitted.
Do let me know if you need any help in setting up any sort of system.
Sending SMS
ok thanks ill have a look at the site, if i set up my own system at home, would you know the approx cost, would i need to buy licences from individual networks.
Sending SMS
No.
Clickatell provide a single point for you to send SMS messages from. How you intergrate it into your application or website, is upto you.
You buy credits from themat about 2p per credit. SMS messages have different proices, bepending on the type of message, and network it goes to.
It costs about 4 pence per standard SMS I recall.
