Script support
Script support
Would would you take " Enable/disable script support" to mean with regards to setting up a web browser? Shockedops:
Thanks for looking
Script support
Huh huh Huh
No idea what you are asking there. Can you try again.
Script support
Could this be JAVA ?
Chilly
take a look
Chilly
take a look at the bottom of 9:
http://www.comptia.org/certification/a/2003_aplus_os_objectives.pdf
Script support
This would refer to enabling/disabling javascript/actix/vbscript and likely Java, within your browser settings.
For Internet Explorer, you would goto option and select the Security tab. By selecting higher security levels or customising them, you can disable them or set them to "prompt".
On a related point. Can I ask where you are performing your A+ certification?
I have been looking into this myself, and simply can't afford nor find the funding to do this course.
Script support
I am doing it the "self study" route. Armed with Mike Myers guide to A+ certification, Exam cram and doing as many google's and tests as I can!
If you are interested go for it. The books are cheap enough and the tests you can book from Pearson vue direct and will cost you around £80 each.
I have done the hardware-just the OS to go! Fingers crossed!
Thanks for the reply by the way.
