SPF Record testing
Fixes: 5
SPF Record testing
Hi all
I have just set up an SPF record on one of my domains. Does anyone know if there is anywhere I can test it to check I have done everything correctly before I go and create the records for all my other domains?
Phil
1 REPLY
craigbrass
SPF Record testing
Go to http://www.dnsreport.com/ and enter your domain. Scroll to the bottom and look for SPF Record.
