SMPT and Plus Net smart host
I am using Linux (fedora) with postfix to send and receive mail. Whist it works fine when I send direct, if I need to use relay.plus.net to send to say AOL who won't accept mail from Hosts they have not approved of, I get the following:
host mx.internal.plus.net[195.166.137.26] said: 550
Please redirect your mail to the plus.net domain (in reply to RCPT TO
command)
I guess that the problem maybe caused becuase I am using my domain name in the HELO, but I am not sure.
Any ideas?
AOL have a very strict policy regarding what IP ranges trhey accept e-mail from.
It is very strongly advised that you continue to use relay.plus.net for e-mails sent there.
You should even be able to setup a rule under your mailcores settings, to use a external smarthost, for all @aol.com addressed messages.
That is what I am trying to do, but relay.plus.net or rather an internal plus net server is rejecting the smtp connection with a 550 error.
I also note that relay.plus.net is also rejecting smtp connetions from evolution which was working until this morning. I suspect that plusnet has changed their rules on relaying.
