SJ Labs Softphone for Pocket PC
http://www.sjlabs.com/
Hi there
Can anyone tell me if they have got the SJ Labs softphone working on a Pocket PC and using it with Plustalk yet??
I have it loaded on my Dell Axim x51v but am unable to get it working as of yet.
Any help would be appreciated.
Sorry for the 2nd thread, last one was a reply but same question.
Cheers
Kevin
I guess thats a no then. I think I might try the aximsite forum.
I have it working using the following settings on an iPAQ:
1. Setup a profile, with profile type ‘Calls through SIP Proxy’
2. Initialization Tab Settings
User data ‘Account’ and ‘Password’ all selected.
Caller ID - none selected
FullAddr of Rec – none selected
3. SIP Proxy Tab Settings
Proxy Domain sip.plus.net : 5060
User Domain sip.plus.net
Register with proxy selected
Proxy is strict outbound not selected
Unregister contact address only selected
4. Advanced Tab and DTMF Tabs
Leave as default.
5. STUN Tab
Use discovered address in SIP Selected
Server Address stun.xten.net:3478
Other settings all default
6. Service Profile settings:
Account Enter SIP ID: 2HuhHuh Etc
Password Enter your plus.net account password
You should now be able to log into the plus talk service. If not check firewall settings, so that ports 3478 and 5060 are open for UDP traffic and forwarded to your PDA device IP address.
N1ck
Works fine for me as well with the above settings - though use a headset otherwise the feedback is horrible.
