Router Firewall.
Router Firewall.
When my router firewall is enabled I am unable to perform tracerts and as a result I have the habit of leaving it off (which might not me a good idea).
I was wondering if anyone knows a way to configure a router firewall to allow tracerts? I have the ADSL 2100 Binatone router.
Also I have the ZoneAlarm software firewall and was wondering if a hardware firewall was actually needed to go along with this?
Router Firewall.
firstly see if the hardware firewall has any TCP filtering // ICMP filtering option enabled, secondly yes, a hardware firewall is always a good thing to have, usualy even better than a software one, however running both is the best.
Replying Ivan
Hi Avonholm,
Your router should definately ALLOW tracert command/s to pass through, and so should work. I'm sure the problem is just a setting that needs enabling or disabling some where in your routers config.
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum, Make Your Voice Count!
