Reverse DNS
Reverse DNS
does Plusnet support reverseDNS to their customers?
buz
Reverse DNS
Yep, just raise a link:contact us ticket and go through the following path:
  • Technical Support (Except Connection problems - See below)
    • Static IP / Reverse DNS Setup
      • Change my Reverse DNS (PTR) configuration
You can then choose which format you would like your rDNS in:
username.plus.com (Default setting)
your_static_ip.plus.com (ie 212_159_0_2.plus.com)
any_host_name.domain.co.uk
Please note that if you wish to use a subdomain, the domain must be hosted with PlusNet.
Reverse DNS
thanks alot
buz
