Reverse DNS help
Alecto
Reverse DNS help
Hello
When I joined PN, Shields Up identified my computer as "myname.plus.com".
After asking on here, I raised a ticket with Pn such that Shields Up saw only my IP number.
I've now by chance found out that "myname.plus.com" is visible again, though I've done nothing to cause it.
Could anyone pse tell me whether Pn have done anything to change this
and what I have to do to change it back.?
holdtight
Reverse DNS help
Same here Geoff having just read this and checking at shields up as i had done the same thing it also now states username.plus.com instead of my ip address which i had changed it to some time ago
So an answer to this would be appreciated as i would rather it was back to how it was before just showing an ip
Im assuming its something PN have done and we have to go through the asking to have it changed back routine :roll:
Reverse DNS help
There is also a thread over on the PlusNet User Group on this issue.
http://usergroup.plus.net/forum/index.php/topic,2468.0/topicseen.html
PlusNet are aware of the problem.
Chilly
Alecto
Reverse DNS help
Thank you chilly.
I can't follow your thread as I've forgotten my login details, but I assume it's a known problem and Pn will solve it when they get round to it.
After everything else.
edit:
Just received an email about it:
We are currently investigating a problem affecting customers' custom rDNS records. Reports from our customers are showing that some rDNS records and have been reset back to the default records. We are currently looking at how many records and have been affected and will post a further update when more information is available.
holdtight
Reverse DNS help
Thanks Chilly !
Bill.
EDIT:
Ive followed your link for a read and im getting this error
[PlusNet Usergroup » Error
An Error Has Occurred!
The topic or board you are looking for appears to be either missing or off limits to you.]
I am logged in without problem any ideas ?
Reverse DNS help
That link is not in the public forums of the PUG message board hence why you got the error.
holdtight
Reverse DNS help
Ok thanks Peter !
Reverse DNS help
Shockedops: sorry guys.
Alecto
Reverse DNS help
I wonder why the PUG needs secret boards then?
Still, seems the problem's sorted now - though Shields Up now displays my IP and plusnet.com whereas before it didn't use to show the plusnet.com.
Is this OK?
Reverse DNS help
The boards are not “secret” in any evil sort of way; they simply provide a communications channel between the PlusNet User Group, and PlusNet staff.
They allow us to raise issues such as the failure of the rDNS with the comm’s team.
Chilly
