Remote access via an internet connection- anyone know how?
I would like connect to a friends PC over the internet. We both have XP on our machines, but use different ISP's. I know it can be done but havn't the faintest clue how to do it. Cry
All the Microsoft help stuff assumes connection to you own office with its own servers, so it is not much help.
Thanks.
Kevin Powell.
glyndev
Don know if this is what you are looking for , but have a look at http://www.tightvnc.com/
Devonports.
Thanks for the response. I may have to resort to using TightVNC, but I understand that XP pro has remote access as standard. I know it can be done; it's the "how to using XP" bit that I havn't got a clue, and need the help with.
If I get no joy from this forum, then I'll try TightVNC
Thanks anyway.
Kevin Powell
XP Pro does indeed have Remote Desktop Connection built in. I think the client installs by default but you need to activate the function to allow others to connect to you. Right-click on My Computer, click Properties. Go to Remote and click on Allow computers to connect to mine. Then add which users are allowed to do this. Mame sure you use a strong password. Then set a port forward on your router on port 3389.
I do this all the time from work. Means I can browse the web without it being logged on work servers Cheesy
Full details of how to set it up
How to Use the Remote Desktop Feature of Windows XP Professional
Applies To
This article was previously published under Q315328
SUMMARY
This article describes how to configure the remote desktop feature in Windows XP. This feature allows remote control of your Windows XP Professional-based computer from another computer running Windows XP Professional or an earlier version of Windows.
MORE INFORMATION
To use Remote Desktop, you need the following:
A remote computer that is running Microsoft Windows XP Professional and is connected to the Internet or on a local area network (LAN).
A local computer running Microsoft Windows XP, Microsoft Windows Millennium Edition (Me), Microsoft Windows 98, Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows NT 4.0, or Microsoft Windows 95, with access to the Internet or the LAN.
Appropriate user accounts and permissions configured on the remote Windows XP Professional to allow remote access.
How to Configure a Remote Desktop
To configure a remote desktop connection between a remote Windows XP Professional-based computer and a local computer running one of the versions of Windows listed earlier in this article, follow these steps.
Step 1: Configure the Remote Computer
On the remote Windows XP Professional-based computer, follow these steps:
Click Start, and then right-click My Computer.
On the shortcut menu that appears, click Properties.
Click the Remote tab, and then click to select the Allow users to connect remotely to this computer check box.
When you are prompted to confirm this change, click OK.
Click Select Remote Users, and then click Add to specify additional user accounts to be granted remote access.
NOTE: Administrators are automatically granted remote access privileges.
When you are finished adding user accounts, click OK. Make sure that the account that is being added does actually exist on the remote computer. If the account does not exist on the remote computer, create it.
Click OK, and then click OK again.
Step 2: Configure the Local Computer
Configure the Remote Desktop feature on the Windows-based computer. To do this, follow these steps:
Insert the Windows XP compact disc (CD) into the CD-ROM drive or DVD-ROM drive on the local computer.
On the Welcome to Microsoft Windows XP screen that appears, click Perform additional tasks.
Click Set up Remote Desktop Connection.
Follow the steps of the Remote Desktop Connection InstallShield Wizard to install Remote Desktop Connection.
NOTE: If Remote Desktop Connection is already installed, you may receive the following error message:
Remote Desktop Connection cannot be installed because your operating system already has a built-in version. See More Programs\Accessories\Communications\Remote Desktop Connections on your start menu.
NOTE: In addition, you can download the Remote Desktop Client from the following Microsoft Web site:
www.microsoft.com/WINDOWSXP/pro/downloads/rdclientdl.asp
Step 3: Connect to the Remote Computer
To connect to the remote Windows XP Professional-based computer, follow these steps:
Log on to the local Windows-based computer.
Make sure that you are connected to the Internet or to the LAN. If you require a dial-up connection to a virtual private network (VPN) or Remote Access server, connect to it.
Click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Click Options.
In the Computer list, type the host name or the IP address of the computer to which you want to connect.
Type the user name, password, and domain (if applicable) of an account to which you have allowed remote access into the corresponding boxes, and then click Connect.
In the Log On to Windows dialog box that appears, type the password of the account with remote access privileges into the Password box .
In the Log on to list, if applicable, select the domain or remote computer that you want, and then click OK.
The remote desktop is displayed in a window on the desktop. The remote Windows XP Professional-based computer is locked during this session.
To disconnect the session, click the Close button in the session window, and then click OK when you are prompted to disconnect the Windows session.
NOTE: If the remote session is displayed in full-screen mode, you may be unable to see the Close button. In this case, restore the window from the remote session banner that is displayed at the top of the session window (click the Restore button).
For additional information about Remote Desktop, click the article numbers below to view the articles in the Microsoft Knowledge Base:
280828 How a Remote Desktop Connection Affects Windows XP Professional
300698 The Features of the Remote Desktop Client in Windows XP
306759 How to Change the Listening Port for Remote Desktop
281262 HOW TO: Turn On Remote Desktop Automatic Logon
The information in this article applies to:
Last Reviewed: 10/8/2003 (2.1)
Keywords: kbhowto kbinfo ocsso kbpubtypekc kbmsccsearch KB315328
Need More Help?
Contact a Support Professional by E-Mail, Online or Phone
© 2004 Microsoft Corporation. All rights reserved. Term of Use Privacy Policy Disability/accessibility
Cheesy Thank you all, particularly mwright whose step by step instruction is exactly what I was hoping for.
Kevin Powell
As a point of interest in the new SP2 for Xp you will be able to have more than one connection to XP so you can both use the same pc like terminal server.
You will? Excelent.
One of my problems at thsi tiem is I have to spend one day a week staying late or getting up early, to account for updates.
This new feature should allow me to perform most tasks from my desk any tiem of the day.
