Remote Connection
Remote Connection
right ,
on the routers, you need to forward port 3389 TCP to the internal ips. Once this is done, on box A go start ->run->mstsc and type the EXTERNAL ip of the other box, it will now connect to that box. this will work both ways.
buz
Remote Connection
Hi, can anyone point me in the right direction to a tutorial on how to set up a connection to my home pc connected to a static IP on Plusnet from my daughters pc on a Broadband connection with a different supplier. I also would like to access applications on either PC. Any help or advice would be greatly appreciated.
Moderators note by John (johnessex) Thread moved to a more apt part of the forums.
Remote Connection
I would recommend that you use VNC - http://www.realvnc.com - which will enable you to access the PC as if it were in front of you.
Ianwild
Remote Connection
Yep - VNC is probably the best way to go...
Is the PC you want to connect to using a USB modem, or a router?
Remote Connection
What's wrong with using RDP?
Remote Connection
Hello Ian, both PC's are using Routers via Lan cards. My ISP is Plusnet and my daughter is on Twest.
Remote Connection
Which ever method you use you will have to open up the port on both routers and point it at the correct pc.
Remote Connection
Are they both runing windows XP pro? if yes, use the Remote desktop built in (right click my computer -> properties -> remote and tick the box to allow remote desktop. to connect .. Start -> run -> mstsc and then type theip of the box u want to connect to
buz
Remote Connection
Thanks for the info everyone, but I am still slightly confused. Both PC's are using ADSL routers, each one connected to the telco provider (BT and Telewest)... As a numpty here wanting to connect both pc's with each one having different different I.P.'s on different networks... eg if I do ipconfig/all I see the address for the local network the local machine uses but no info on the static address Plusnet has assigned to me, even though I know what it is. Given the 2 pieces of information, local address on the home network and that assigned by Plusnet how do I then get both machines talking... Both machines are on different networks and more than a hundred miles apart.... Any help would be appreciated. Thanks Paul
