Redirect sort of thing
I know what I'm asking for is probobly impossible but it is worth a shot...
Is there a way to redirect viewers of my (www.) site to pages on my cgi space without changing what is in the address bar and without using frames.
I currently use frames on my site but it results in an annoying white line down the right hand side in mozilla browsers.
1 REPLY
michaelscott
it probably is impossible. the white line you describe can only be down to an error in your code. i've used framesets for the same purpose as you and have had no problems
