Real Audio on a plusnet question.
I would like to use RealAudio files from a plusnet web site, does anyone here have experience of this?
There is a web site http://www.htmlgoodies.com/tutors/ra.html that explains how to set it up but does plusnet have the nessesary MIME type settings:
audio/x-pn-realaudio (files with a .ra or .ram file extension)
audio/x-pn-realaudio-plugin (files with a .rpm file extension)
Any help or pointers to sites that do this would be appreciated.
1 REPLY
As far as I can tell the following do exist:
audio/x-pn-realaudio ram rm
audio/x-pn-realaudio-plugin rpm
audio/x-realaudio ra
So it should work.
Try it and see if it works. If not you can set the necessary MIME types in a .htaccess file which you can put in your root (home) directory. See General: .htaccess for instructions on how to do this.
