RIP parameters on router/modem
kissack
I have an AR41 and notice that one of the settings is to set RIP parameters. The 'help' isnt and I wondered if anyone knew what RIP stands for and what I can achieve by using it?
RIP stands for routing information protocol and is of no use to you unless your private network contains multiple subnets.
Darren.
kissack
Thanks Darren.
I don't, so I'll leave these well alone then
Changing these will not harm your router or network.
RIP is the phonebook of a network. It tells devices through which devices data needs to go to get to its destination.
If you do or don't send it, it doesn't matter
