Proxy settings
Proxy settings
Can someone explain what they are, how they are normally set and why you would to change them. Thanks Cheesy
Proxy settings
where? in IE?
Proxy settings are to tell your computer where to send all internet bound traffic first, eg to ur gateway PC, or from the gateway to a proxy online that will then forward the packets to the original destination, and thus masking your own IP.
The are normaly automaticaly configured in IE // XP to the default Gateway that you set in your network connections, however if you goto tools -> internet options -> connections you can set your own one up (one thaty ou find on a proxy listing website maybe)
You would want to change them to mask your identity, if you get known as an ip (even a proxied ip) then some one can ban that ip, so all you do is change your proxy, and your entire identity onilne changes.
thanks!
Thanks for the explanation. It is a setting i came across while going through the settings in firefox and wondered what it was! Cheesy
