Problems with Referrals Banner.
jeffkey
I have added the referrals banner to one of my pages and looking at the page from work it all looks fine.
But it does not display at home on Plusnet ADSL.
I have these three things running, one of them must be blocking it...
1) Firewall on Netgear DG834G
2) Norton Internet Security
3) Windows XP firewall
or its my local Explorer Setting.
Any ideas.
What setting do I check :?:
Running XP, SP1.
jeffkey
28th August 11:28 posting.
I think there is a clock messed up some where !!!!!
Are you running any IP blocking programs such as peer guardian etc?
jeffkey
No,
Only Norton Internet Security, the Hardware Fire wall in the Modem and Xp's Firewall.
Norton already contains a firewall, so you don't need XP firewall. You'll find your'll get conflicts if you run two firewalls.
jeffkey
Yep, makes sense. Will try off XP firewall.
See what happends.
off topic:
Yes yours - actualy it's the timezone in your profile that is set wrong - click on profile at the top and set the timezone field to GMT+1 and save it.
jeffkey
done and fixed .... thanks.
Moderators note (John) Quote removed as its not needed.. Please don't post the entire contents of the post preceding your reply.
jeffkey
ok. back on topic.
I have turned off XP Firewall and Norton Firewall (for a short test) and no joy.
Looking at the Netgear Firewall every thing inbound is blocked according to the setup.
Will try this next.
What service, if any is ok to turn on?
Your netgear router inbound rule would not affect this, the inbound rule covers traffic which didn't originate from your PC and that is inbound.
The rule is a default rule and cannot be changed or removed. If you add a rule to allow all inbound traffic, then the firewall on your router might as well not exists and your pc would be left to the protection of Norton Sad
Do you have any outbound rules?
Is the site address, www.jeffkey.plus.com, since I just tried the address and the banner doesn't display for me either. Yet my site (still building) works with the banner.
Have you checked the banner code, or maybe I've connected to the wrong site.
Aaron
jeffkey
the site is :
http://www.jeffkey.plus.com/contact.html
If any one can tell me if they can see the banner it would help.
PS Its problably a bit small but I will fix that tonight.
Yep, I can see the banner at the top. It is a bit squashed as you say Cheesy
jeffkey
Thanks Chis,
Should be fixed now.
But still does not show on system at home.
Some thing is blocking it.....
It now shows 3 banners (all on the same line) which are each of a regular size now Smiley The first one is clickable, but the others are not.
jeffkey
I was just trying to get the banners to come up as gifs.....
There should now be just one banner on the top of the page.
Funny when I right click and show source in I.E 6.0 the line
<img src="http://portal.plus.net/images/banners/banner_2.gif" border="0" width="320" height="32"></a>
is not there.
I wonder if I have a banner ad blocker running some where Huh?
Moderators note (John) Code tags inserted for you to improve the readability Cool
