Problems with MIRC
Problems with MIRC
Ever since I moved from cable to plusnet ADSL I am getting lots of problems with IRC. I keep getting disconnected with the following error :
* [10053] Software caused connection abort
May be totally unrelated to the broadband move but thought it would be worth mentioning anyway. Any ideas folks ?
Many Thanks !
Problems with MIRC
It's likely a IRC server under a dos attack ie Qnet during any time of the day. So find a local server and use it but not to join not via the load balance of the main IP address.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Problems with MIRC
Check your using the latest version of mIRC because an exploit was found recently, and if your not using a patched version, people may be able to crash your client.
Problems with MIRC
There are two exploits you are talking of.
One would work regardless of settings and a update was made. A second one on the newer version requires a speicifc set of options set.
Both of these exploits cause mIRC to crash and exit with a exception error. Connection aborting is a seperate issue.
