Problems registering asterisk server
I have the following register line in my asterisk's sip.conf file;
register => plustalk@<username>.plus.com:<password>@sip.plus.net/plustalk
By when I reload asterisk I'm getting a message that says;
Dec 26 22:39:07 NOTICE[14080]: chan_sip.c:4701 sip_reg_timeout: -- Registration for 'plustalk@<username>.plus.com@sip.plus.net' timed out, trying again (Attempt #1)
Anyone have any ideas why I can't register?
Chris
Same here!!
Hi
I have the same problems i have got the reg string now but cant make calls seems to be some auth problem. I called tech support but it was a bit over the guys head.
Can anyone help?Huh
same problem here
Try this in sip.conf....
register => plustalk@<host_name>.plus.com:<acct_passwd>@plustalk_plusnet/plustalk
[plustalk_plusnet]
type=friend
context=incoming-sip-plustalk
username=plustalk@<host_name>.plus.com
secret=<acct_passwd>
fromuser=plustalk
fromdomain=<host_name>.plus.com
host=sip.plus.net
insecure=invite
canreinvite=no
accountcode=plustalk
disallow=all
allow=ulaw
allow=alaw
The contect [plustalk_plusnet] is still in 'flux' as I am playing to get the best settings for my needs but it works for calls in both directions.
I do however get:
Jan 30 21:36:28 WARNING[30916]: chan_sip.c:9510 handle_response_register: Got 200 OK on REGISTER that isn't a register
Doesn't cause me an issue but it's there!! Probably need to upgrade.
Stuart.
