Problems accessing some sites.
Hello,
Could someone see if they are have the same problems as me. I am trying to access some sites on http://www.calsnet.net/ but haven't been able to for several days. I can access the site if I dial up through my BTOW connection, just not through PlusNet ADSL or dialup.
Thanks,
Michael
its hosted in US and looks like 2 hops in US are having difficulties, atm there dropping pings so might have been worked on recently.
But that site works for me.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
No it doesn't work for me and Visual route says it is unknown. :?
You need to drop the " , " off the link.
Must be a routing problem, DNS problem or redirect problem somewhere. Try the alternate address of www.calendars.net :lol:
Thanks - the alternative link works for me, but unfortunately if you click on a users calendar the link still does not work!
longedge - I know the comma should not be there - but the link still does not work without it!
...hmmm strange that. I just clicked on your edited link and it worked. The url goes to a re-directed (as in cqg4uzg's post) page and that also worked.
There's certainly something odd with the routing, last night I could ping it but tracert was failing after several hops at cogent.com I think it was.
Niveus - It may be the DNS servers at plusnet as I get no ping and no host on DNS search. Works DSL access works fine.
I am using 212.159.13.49 and 212.159.13.50
What server are you using ?, I guess you are using the same as me and longedge is using the alternate DNS servers 212.159.11.150 and 212.159.13.150
Gordon
The link doesn't work for me in Opera, but does in IE. Strange.
Still doesn't work for me with IE 6 ?
Gordon
Nope -just checked ipconfig and I am on 212.159.13.49 and 212.159.13.50.
Also re-checked the link and it still works for me ( forced a refresh just to make sure). I'm on IE6.
Can ping www.calsnet.net no problem but -
Tracing route to my.calendars.net [207.202.158.20]
over a maximum of 30 hops:
1 22 ms 20 ms 21 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
2 22 ms 21 ms 21 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
3 22 ms 22 ms 23 ms gi5-0-4.pth-gw2.plus.net [195.166.129.22]
4 22 ms 23 ms 22 ms 195.66.226.175
5 95 ms 95 ms 96 ms p13-0.core02.jfk02.atlas.cogentco.com [130.117.1.18]
6 137 ms 139 ms 139 ms p14-0.core02.ord01.atlas.cogentco.com [66.28.4.86]
7 137 ms 137 ms 138 ms p12-0.core01.mci01.atlas.cogentco.com [66.28.4.33]
8 149 ms 151 ms 147 ms p5-0.core01.den01.atlas.cogentco.com [66.28.4.29]
9 189 ms 191 ms 189 ms p5-0.core01.sea01.atlas.cogentco.com [66.28.4.101]
10 190 ms 189 ms 191 ms g0-2.na01.b001703-8.sea01.atlas.cogentco.com [66.250.11.94]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * *
Hmmm, there is something going on...
Try www.calsnet.com and it should work. Works in both Mozilla (Linux) and IE6 (WinXP) - note.COM and not .NET !!
www.calendars.net and www.calendars.com give two different sites, could be a domain fued going on.
