Problem with network connection??
I have a wireless network lan at home, using the Safecom ADSL modem it has 1 usb port and 1 ethernet port. The wireless network is ok no problems however, when I plug a computer into the lan socket and try to get on the web it is very slow, it connects ok but downloading web pages is very very slow. My wireless laptop is ok no problems. Anyone any suggestions? Please.
This is driving me crazy, the nic in question is using the realtec 8139c chip set, the connect is very very slow more so when dowloading web pages? I have tried the cable on my laptop and that works ok. Any help please.
DHCP ? // firewalls? // what speed is the Nic connecting at? it could be a confliction between full / half duplex.
I think some more information is needed about your setup, ie. how your wireless network is setup?
It's worth mention that most modems or routers, which have both USB and Ethernet, can only handle one at time.
Finally, if everything else works fine by cable, it suggests can issue with the network card. It either needs replacing, new drivers, or your PC has some setup issue / virus / spyware.
