Port scanned, plus net user ?
Not sure about this but my firewall says ....
IP 212.159.124.*** scanned ports 2745, 1025, 445, 3127 and 6129
Is this somebody being naughty or a mistake ?
Can I get something done about it ?
What does the ports do ?
Thanks.
Please send details of what you are seeing plus your firewall log showing the scans to abuse@plus.net and it will be dealt with. It is likely to be an infected PC which the owner is not aware of it.
We have had several similar threads on this:
http://portal.plus.net/central/forums/viewtopic.php?t=15800
http://portal.plus.net/central/forums/viewtopic.php?t=15786
http://portal.plus.net/central/forums/viewtopic.php?t=15934
Some links to find out what the ports are used for:
http://www.iana.org/assignments/port-numbers and http://ccr.i2.nscee.edu/port/ contain info about port uses, the second you can search for multiple uses.
There lots more than there should be, so I'm putting a pc in to DMZ for a day or two. Going to log all PN users and mail them as I did for Blaster when it came out initially.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: Port scanned, plus net user ?
From what I've been reading scans on these ports are a likely indication of a PC being infected by one of the Gaobot/Agobot/Phatbot family of worm viruses.
Potentially bad news for these people if this is the case as it provides a backdoor for somebody to access their machine...
Mark.
Anybody heard of industry58, tracert to IP address in firewall log points to industry58.force9.co.uk :x Ticket raised, awaiting reply.
dont wait for a reply from an abuse ticket, you won't get one unless that person in your logs tried to attack your modem/router
PlusNet have stated in several threads they can't always reply to all abuse reports due to the number of them they get but they do still investigate and if necessary contact the offending person to take action to stop the activities.
