Port Forwarding Software
michaelscott
I used to have a piece of software that would sit on a machine, listen for connections on a specific port and then forward them to any other machine or itself, on either the same or a different port. I need a similar piece of software that can forward on a different port but I can't find it anymore.
Any suggestions?
1 REPLY
michaelscott
I couldn't find it because I was looking for port forwarding software. i should have been looking for port mapping Shockedops:
AnalogX PortMapper does the job
