Port 25 ?
Port 25 ?
Do plust net block port 25 by default ? I did a pen test after I turned the firewall off and port 25 is still showing up as stealth ?!
Port 25 ?
No they dont. No ports are blocked other than on a home surf account which blocks peer to peer and some usenet traffic.
Chris
Port 25 ?
And they're blocking 135 and 445 at the edges of the network, to prevent further spread of the blaster virus (though they may have lifted this restriction by now).
Port 25 ?
Sobig doesn't spread via netowrk connections, just e-mail.
You are talking of Blaster.
Port 25 ?
Of course I am - silly me Smiley
Port 25 ?
hmm, seems like my EN 5930 is playing silly buggers then :-(
Port 25 ?
Where have you had problems concerning port 25?
Port 25 ?
I'm just trying to test incoming SMTP connections over NAT for when we transfer are mail over to plus net, not having much joy at the moment!
Port 25 ?
I assume that if you're using a router, you have forwarded the correct ports?
Port 25 ?
yeah, what it was though was the machine that the port was being forwarded to had a personal firewall running as a service. d'oh!
Port 25 ?
Hehe - so your problem's been solved?
Port 25 ?
yeah that one has, just need to figure out the vpn now Sad
