Plustalk with Netgear DG834
The_10th
Anyone got X-lite to work with the above equipment and if so what settings were applied?
Thanks Cheesy
Didn't apply any settings to the router as X-lite read the router and worked.
The_10th
Thanks for the reply. I received a reply from support with a known issue logging into plustalk at present.
The_10th
All working now (following the plusnet tech support fixing the authentication issue) after changing some settings (some on the portal and others not.) Cheesy
