Plusnets SMTP
Plusnets SMTP
anyone know of any issues at the moment? I can retireve mail fine in their Pop3 but cant send mail on smtp. All settings are correct, in OE the send progress bar fills up to full but the mail wont send. I have just added a netgear DG834G adsl modem/router as my means of accessing the internet, everything else is working fine. I dont think its the firewall on the router and i've made rules to allow anything in/out with no difference in the results.
I was using the binatone modem supplied by plusnet before, should I have to change any settings anywhere or do anything different?
Any advice appreciated.
Mark
csogilvie
Plusnets SMTP
It probably doesn't help, but I can send through relay.plus.net fine at the moment.
Plusnets SMTP
cheers thought as much. Just discovered that the other machine on my network isnt sening mails either. I'll go and have a look at the settings again.
Cheers
Mark
Plusnets SMTP
problem solved
changed the mtu size from default 1448 or whatever it was to 1500 and mails work fine. Should have remembered this tip from when i last set one of these routers up for somebody else!
