PlusTalk Help and Support
Feel free to ask any questions you have about PlusTalk in this forum. Our support team will be glad to help, and other PlusTalk users may have the answers for you too!
We’ve also got a dedicated PlusTalk support section area in our support pages, including setup guides, a glossary and Frequently Asked Questions.
PlusTalk support - http://www.f9.net.uk/support/adsl/voice/
Alternatively you can get in touch with our support team using Contact Us or by phone on 0845 1400250.
Regards,
Customer Support
Retrieving voicemail messages from your PlusTalk phone is easy:
1. Dial 7001
2. When asked for your mailbox enter your SIP ID
3. When asked for your password enter your Voicemail PIN
4. Press 1 to listen to your new Voicemail.
You can find your SIP ID and Voicemail PIN on the My Accounts page of the PlusTalk control panel.
For more information on retrieving your voicemail please see the PlusTalk User guide.
Please note, when using 7001 Voicemail, use the # key whenever you are prompted to press the pound key.
hi guys, the above link doesnt work, did you mean:
http://www.f9.net.uk/support/adsl/plustalk_support/
Cheers,
Dan
orrery
I'm on broadband PAYG.
Will the VOIP traffic be metered, or is it excluded?
If it is metered, what is the approx bandwidth per minute of call?
regards, Ian
Bandwith about 70-80 MB/hour
According to Sipgate you use about 70-80MB per hour of call, about 100Kb each direction each second.
