PlusNet banner referal ads
strange isn't it, came across this a long time ago.
would of thought it would have been sorted by now :lol:
probably like me, you just looked at the code, highlighted what was needed and pasted without reading the rest of the page Smiley caught me out first time I did it, been a while since I touched html.
I have tried pasting the PlusNet banners produced under "My Referals" on this site, but everytime I paste them into the site, I can see the HTML text, rather than the banner... (I paste the text into the HTML tab in frontpage, and I have tried several different locations but they all do the same).
I have to admit I am a complete doughnut on this sort of stuff Shockedops: so its likely to be something stupid I'm doing
whats the link?
sounds like a html error.
www.cattells.net ... it looks like a real mess at the moment, but I'll tidy it up if I can fix the banner thing.... any help you can give would be great :lol:
[edit] Link removed, no longer needed [/edit]
Lemme guess.... you copied and pasted directly from the Plus.Net banners page? I did the same and it wouldn't work, what you need to do is copy and paste into say notepad, then copy and paste from notepad into Frontpage html.
try it both ways, you will see that copy and paste direct from Plus.Net page doesn't not paste correctly Wink
this is what copy and paste from Plus.Net looks like
<I>&a
href='http://portal.plus.net/my/mydiscount_info/landing_page.html?zWVl6A8AruuylVaHtkq2oaDANJD6wbPjpFANHoQMl5A%3D'&<BR>&img
src='http://portal.plus.net/images/banners/banner_9.gif'
border='0'&<BR>&/a&</I>
this is what it looks like from notepad
<a href='http://portal.plus.net/my/mydiscount_info/landing_page.html?zWVl6A8AruuylVaHtkq2oaDANJD6wbPjpFANHoQMl5A%3D'>
<img src='http://portal.plus.net/images/banners/banner_9.gif' border='0'>
</a>
Its fixed....
Thanks Chris.... it works.... I really do not understand why, but you are correct... pasting via the notepad works. I think it says something on the banner page, but its not too obvious.
Thanks, that's a great help
Pete
It's caused by the way front page handles the paste from clipboard function, I tried the same operation into netobjects and it worked without having to copy it into notepad first.
ahhhhhhh I see..... maybe time to ditch it for dreamweaver Smiley
