Plus Net Web Space
Plus Net Web Space
Hey,
ive got myusername.plus.com pointing to my webspace can i change it and point it to my static ip address? if so where do i go to do? any help would be greatly appricated.
Tim
Plus Net Web Space
Do you mean a reverse DNS lookup on your IP address gives your web address.
You can change it via contact us
Click on new query -> Technical support -> static IP/reverse DNS setup
Then read the info page and select change my reverse DNS thsi in the uticket ask for your rDNS to be changed to your IP address.
It will then take about 24 hours before it is changed.
[append]
Or did you mean you want to host your own website on your own PC?
Plus Net Web Space
No i ment i wanted to host my own website on my pc
Plus Net Web Space
You need your own domain to do that.
Plus Net Web Space
ok, By the way i just set up a forum on my computer, check it out, at http://80.229.33.172/phpbb2/index.php Tell me what you think and tell me any problems you find, thanks tim
michaelscott
Plus Net Web Space
http://assimulator.plus.com should already point to your computer
http://www.assimulator.plus.com/ will point to your webspace.
Plus Net Web Space
It does? I don't think so ...
michaelscott
Plus Net Web Space
yes, it does.
http://michaelscott.plus.com/ <- my webserver
http://www.michaelscott.plus.com/ <- my webspace
Plus Net Web Space
Interesting. Is this documented anywhere?
michaelscott
Plus Net Web Space
not that i've seen. additionally, when you visit sites your hit will show up as yourname.plus.com in their logs.
Plus Net Web Space
Useful to know. Thanks for pointing it out.
