PhoneSkype SK-04
PhoneSkype SK-04
Hi
I recieved this phone th is morning, and so far I have had limited sucess setting it up. The documentation claims that it is compatible with Xten and Xlite.
At the moment, the phone rings when I get an incoming plustalk call, but I cannot answer it using the phone itself, I have to use the x-lite software to answer the call.
Also, I cannot make calls with the phone (i have enabled it in the x-lite menu)
ANy ideas anybody?
PhoneSkype SK-04
Hi Marc,
I'm not familiar with that phone, but if it is a usb phone there is an update for X-Lite which will enable compaibility and functionality with usb phones.
The software is provided and supported by X-Ten and can be downloaded Here
Let me know how it goes if you would. Smiley
PhoneSkype SK-04
Hi Mark
I already had that update, but had the some settings worng
It now works fine, thanks for the tip
Marc
PhoneSkype SK-04
You're welcome.
Glad you are up and running. Smiley
