Phone Router - even need computer on?
Does anyone know - if I buy this Broadband Phone Router (SpeedTouch 716 WL).... do you actually need the computer on to make and receive calls?
http://portal.plus.net/products/hardware/voice/voice_router_kit.shtml
It looks like you just plug a VoIP phone into it and away you go...? Now that would be cool!
Thanks for any help,
Jim
1 REPLY
You do not need the computer on. The settings are in the router. You will need a DECT phone (an ordinary BT phone) to plug into it. I bought a cheap one (£4.95) for the job and it works fine.
