Peering with Voipfone
dgp
I have managed to successfully dial-out to Voipfone using sip peering, but when I try and dial Plusnet from Voipfone I get the message ' the number you have dialed is not in service, please check the number and dial again'. I have used the short code and the full sip address, each time I get the same response. The Plustalk line is working fine if you dial in from PSTN. Any ideas?.
Dave
