Parental control software
Hi
Has anyone got any recommendations? using XP home.
There seems to be a lot of choice in the market.
Rgds
How old are the children and what do you want to stop them doing? It is important to know what you want to achieve before recomending anything.
For some it may be nude images and for others it may be more wide spread and include other none sexual blocking
Hi
Pornography mainly
Have a look at McAfee Internet Secuity also one of the problems related with Parental software is that it tends to block education information as well another thing i might suggest and many find it not the best idea is keep you computer where you can keep an eye of the usage for example in the living room or limit the time the child can use the internet cos there are many ways around Parental Control Software
Hope that helps
B Gone (freeware), developed by yours truly
http://www.it-mate.co.uk/support/bgone.asp
kissack
if you have spare hardware (ie a 486+ to install on), ipcop with the dansguardian add-on is very good. ipcop offers a very effective firewall to any home network/pc. Dansguardian is very customisable and rather than relying on 'blocked' sites also looks for 'banned' words in the requested page content.
